Please help me about OOS platform state of standby PGW
Jul 13th, 2006
Hi experts,
I 'm installing 2 PGWs 9.2.2 on 2 sunfires v120 (one disk on one sun). I followed the guides on Cisco Install guide doccuments.
The procedure I do :
1 - Install Sun solaris 8
2 - Install Patch CSCOh015
3 - Install MGC software 9.2.2
4 - Install Patch CSCOh013
I configured the parameters on XECfgParm.dat as the guides of Cisco for redundant system.
2 PGW status is : active and OOS (Out Of Service). If a PGW run first, it will get Active. If I stop MGC in Active PGW,and after restart it will be on OOS, the other will be in active automatically.
This is parameters I configure:
Parameter: Master---------------------Slave
PlatformID: 1------------------------2
transpathId: 01-----------------------02
owntranspathid: 01-----------------------02
peertranspathid: 02-----------------------01
desiredPlatformState: master----------------slave
SyscheckpointEnabled: true------------------true
IpAddrLocalA: 221.133.1.162------------221.133.1.163
IpAddrPeerA: 221.133.1.163------------221.133.1.162
IP_addr1: 221.133.1.162------------221.133.1.163
stPort: 7000--------------------------7001
pom.dataSync: true-------------------------true
foverd.ipLocalPortA: 1051-------------------1052
foverd.ipPeerPortA: 1052-------------------1051
chkPtPort: 2001------------------------2001
pom.Port: default (4001)----default
the others is set as default
2 PGWs connected to SW 3500 Cisco via every eri0 of them.
I configured PGWs like: speed 100 and mode link: fullduplex
PGW A and B can ping each other
I check platform.log file on them.
This is log file in PGWA:
Fri Jul 14 06:07:41:434 2006 GMT | foverd (MM)(PGWtest1) (PID 745) <Warning>
GEN_WARN_FOVERD: Invalid msg number
Fri Jul 14 06:07:50:559 2006 GMT | replicator (PID 13) <Error>
LinkA:ReceiverComm: recv failed, disconnecting.
Fri Jul 14 06:07:50:560 2006 GMT | replicator (PID 13) <Error>
LinkA: disconnecting.
This is log file in PGWB:
Fri Jul 14 10:09:24:160 2006 GMT | ProcessManager (PID 1031) <Error>
GEN_ERR_TIMEOUT_PROC: procMActMgdProc::handleTxnTmo Heartbeat response timeout timeout for CDRDMPR-01 process.
Fri Jul 14 10:09:24:920 2006 GMT | ProcessManager (PID 1031) <Error>
GEN_ERR_TIMEOUT_PROC: procMActMgdProc::handleTxnTmo Heartbeat response timeout timeout for CFM-01 process.
Fri Jul 14 10:09:25:680 2006 GMT | ProcessManager (PID 1031) <Error>
GEN_ERR_TIMEOUT_PROC: procMActMgdProc::handleTxnTmo Heartbeat response timeout timeout for MM-01 process.
Fri Jul 14 10:09:29:369 2006 GMT | cdrDmpr (PID 11332) <Error>
Unsuccessful completion
Fri Jul 14 10:09:30:121 2006 GMT | ConfigManager (PID 11333) <Error>
Fri Jul 14 10:09:30:122 2006 GMT | ConfigManager (PID 11333) <Error>
Fri Jul 14 10:09:30:999 2006 GMT | MeasurementManager (PID 11334) <Error>
Fri Jul 14 10:09:31:004 2006 GMT | MeasurementManager (PID 11334) <Error>
I look forward to your helps and thanking for that
Best regards,
David,
NOC dept. Saigonpostel corp.
Ho Chi Minh City, Vietnam
CCNP CSCO10707495
anikas Thu, 08/03/2006 - 11:55
  • Cisco Employee,
David,
First, I would like to point out that 9.2.2 went (EOS) End of Sale in February 4, 2005 as per this URL:
http://www.cisco.com/en/US/products/hw/vcallcon/ps2027/prod_eol_notice0900aecd8013f44b.html
Next, It does not look like you have the CSCO MGC patches loaded on your system.
Finally, it sounds like you have not confgured any DPCs or linksets in the system. If this is the case then the standby will not go in the STANDBY state but remain OOS.
Hope this helps,
Andreas
spt177 Mon, 09/18/2006 - 03:18
Thanks all,
I only connect 2 PGW sun server on 1 switch.
I haven't yet configured any DPCs or linksets.
This project is only used to test synchronize each other.
Thanks for your comments.
