Warning message
rme3.5 - config backup
Jul 14th, 2006
i am new to cw2k and am learning how the device (config) backup works. does it perform a baseline (when i do archive) and then only downloads a config it changes when performing another archive? Can it download a config on demand, even if it does not have any changes?
David Stanford Fri, 07/14/2006 - 04:03
  • Cisco Employee,
Hi Matt,
When you initially add a device to RME it will go out and archive the config of the device automatically and place it in the config archive after that.
Once that is done you have a couple of options:
1) You can use periodic polling to go out and check for config changes to pull a new config or you can have RME pull the config if it receives a config change syslog message
2) You can schedule an inventory collection to pull a config regardless of config changes on the device.
matt.walls Fri, 07/14/2006 - 04:41
okay. that is what i have experienced. on option 2)
would i then:
RME - Admin - inventory - update inventory (on the device/s) that i want current configs?
David Stanford Fri, 07/14/2006 - 04:48
  • Cisco Employee,
You would go to RME - Configuration Management - Update Archive
The other option you mentions above updates the inventory of a device...i.e. hardware
you can also schedule a full config retrievel by going to RME - Admin - Config Mgmt - General Setup - Change Probe Setup
matt.walls Fri, 07/14/2006 - 04:55
when i do the: RME - Configuration Management - Update Archive. it says successful for each device... with today's date. (note these devices configs have not changed). but when i go to rme - config mgmt - search archiive by device and i select them it only shows the most recent archive as when these configs were last changed/downloaded.
matt.walls Fri, 07/14/2006 - 05:12
g.locatelli Wed, 07/19/2006 - 06:54
It only saves the configuration if it detects that a change was made. The feeling is that you don't want to fill up disk with duplicate data.
