Warning message
irisrios Thu, 07/20/2006 - 11:51
  • Silver, 250 points or more
This is usually indicative that the BACC Servers and DPE are out of sync by a timeframe larger than 5 minutes.
David Stanford Mon, 07/24/2006 - 04:38
  • Cisco Employee,
These errors usually indicate that the DPE, RDU and KDC server are greater than 5 minutes out of sync.
What are the current times on each of these devices? What are the timestamps on the CM/MTA's reporting?
You might want to have a look at the dpe logs as well.
Also, what is the current load on the DPE? What does a show dpe return?
