miheg Sun, 07/16/2006 - 23:57
  • Gold, 750 points or more
Better use the logrot utility in CSCOpx\bin.
The way it works in explained in the helpfile, but you can say what the max size can be for a file and how many versions it keeps.
Anyway Joe (jclark) can tell you all about this one.
you should also read post "Network Management: LMS Server Preventive Maintenance"
Cheers,
Michel
