Warning message
trunking between 7613 and GSR (12416)
Jul 17th, 2006
Can these 2 devices support gig etherchannelling? I need to trunk 3 gig ethernet between 7613 and 12416. GSR does support portchannels but to allow trunking dot1q must be configured. If any one is doing this please print a sample config.
Thanks.
Roberto Salazar Mon, 07/17/2006 - 19:38
  • Gold, 750 points or more
7613 definitely supports port-channeling and dot1q trunking on those channels. Waht is the issue? Are you not able to trunk?
Please rate all posts.
j.belarj Tue, 07/18/2006 - 04:12
I can trunk between 2 cisco 7613's not a problem. My issue is I have a 7613 and a 12416 at same location and I need to trunk them. Not sure if this will work, I can't find any documentation to support creating L2 interfaces on GSR so I can trunk them.
Any one with any White Papper, or experience please reply before I open a TAC case.
Thanks.
Roberto Salazar Tue, 07/18/2006 - 16:24
As far as I know the GSR will be able to support dot1q trunk. So, you will need to channel the gig interfaces and create a L3 port-channel interface and sub-interface the port-channel with dot1q encapsulation.
jackyoung Tue, 07/18/2006 - 17:05
According to the Q&A as below. The Fast and Gigabit Etherchannel is not supported in GSR12000. And it do support 802.1q.
http://www.cisco.com/en/US/products/hw/routers/ps167/products_qanda_item09186a0080094a71.shtml#n17
Below is the config, sample for dot1q for VLAN 10 :
interface gigabitethernet 3/1.1
encapsulation dot1q 10
ip address 172.1.1.1 255.255.255.0
http://www.cisco.com/en/US/products/sw/iosswrel/ps1829/products_feature_guide09186a00800e9556.html#31333
Hope this helps.
j.belarj Thu, 07/27/2006 - 06:37
Yes Indeed only L3 etherchannels are supported on GSR 12416... and trunking using them is possible.
Thanks.
