Warning message
NAC VPN
Jul 17th, 2006
I finish IPsec Remote access tunnel in Pix515 with 7.2.1 version, and i want enable NAC for this connection,
I have configured the pix with the user guide, but i don?t find information about the CSACS configuration. Can anyone help me?
Regards.
sachinverma Mon, 07/17/2006 - 23:22
You must configure at least one Cisco Access Control Server to support NAC. Then use the aaa-server host command to name the Access Control Server group even if the group contains only one server.To configure NAC,kindly refer to following document.
http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_chapter09186a008066ebb8.html
Let me know if it helps.Kindly rate this post.
Ernesto Fernand... Wed, 07/19/2006 - 05:17
I have the VPN conection stablish and i see the Group in the correct profile, but the posture validation process don?t launch, in the pix log i see
%PIX-6-334001: EAPoUDP association initiated - 192.168.254.10
%PIX-5-334006: EAPoUDP failed to get a response from host - 192.168.254.10
I have CTA 2.0.1.14, CSACS 4.0 and VPN client 4.8.01
Regards.
m_chernogorsky Fri, 04/20/2007 - 01:14
Hello, as i understand from you future message,
you configure pix to wok with CTA
How ? ^-)
Now I Have the same problem
CTA installed
Vivek Santuka Mon, 04/23/2007 - 07:30
  • Cisco Employee,
Please check if CTA EOUDP service is running and also try increasing the EOUDP timeout on the PIX.
eou timeout retransmit 15
Vivek
