Warning message
urgent: can't logon to switch after conf microsoft Radius for logon
Answered Question
Jul 17th, 2006
Hi forum,
i can't logon to my switch after configuring logon with microsoft Radius, my configuration is as follow:
username nwadmin privilege 15 password 7
username yeopaul privilege 15 password 7
aaa new-model
aaa authentication login default group XXXRADIUS local enable
aaa group server radius XXXRADIUS
server X.X.X.X
radius-server host X.X.X.X auth-port 1645 acct-port 1646 timeout 60 retransmit 3 key XXXXX
on the microsoft radius server, i can see from the security event that the authentication is successful. However, the system event show the logon fail, reason : the user attempt to use an authentication method that is not enabled on the matching remote access policy.
how do I recover the switch's access?(it is my core switch running HSRP with another)
what could be the cause of this problem?
Appreciate your help.
Thanks and Best regards,
Paul
Overall Rating: 4 (1 ratings)
paulnigel Mon, 07/24/2006 - 16:11
Thanks much Wong,
it resolved my issue. Cisco is actually using pap so i alter the policy to use pap, then it goes through.
somehow i don't understand why even after i shutdown the Radius server, the switches still do not refer to the local user database for authentication, but when i did the same thing on my ASA, it does work.
Thanks and regards,
paul
