How to see unassigned DNs in 3.3
Jul 18th, 2006
using CM 4.0 and above you can list the unassigned DNs via the Route Plan Report. Is there a way to see these using CM 3.3 as this option does not exist.
cheers,
Mike
Chris Deren Tue, 07/18/2006 - 07:13
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
No, with CCM 3.3 and prior and you deleted DN it was pernamently deleted unlike CCM 4.0+, you can use Route Plan report to see whay DNs are not listed and use those. CCM 4.0+ does not really list all unassigned numbers, it lists the DNs that have been deleted.
HTH, please rate all posts!
Chris
michael.e.reid Thu, 07/20/2006 - 00:15
Hi, thanks.
Is there any documentation for this script ?
We only want to delete auto assigned DNs that are not being used and visible in the webgui.
cheers,
Mike
gogasca Thu, 07/20/2006 - 08:18
  • Green, 3000 points or more
Unfortunatly no.
Its an Internal Cisco tool.
Its pretty straightforward as u can see.
