Warning message
conn vs xlate
m.sir Wed, 07/19/2006 - 00:24
  • Gold, 750 points or more
If client is connected to same server via telnet, FTP, and HTTP simultaneously so there are three separate TCP connections between the two devices - it would create a single translation slot (its between PC and server you can check with show xlate) and three connection slots (telnet, ftp, http - check it with show conn). Each connection slot is bound to a translation slot.
M.
Hope that helps rate if it does
i know this before itself. i got a problem from customer and he had send the following
Xlate:
PAT Global 10.32.60.45(1203) Local 10.239.32.49(2228)
Conn:
TCP out 10.80.134.181:3389 in 10.239.32.49:2228 idle 0:00:02 bytes 0
flags
so here i believe that the conn is initited by 10.80.134.181 to 10.239.32.49 with out translation..
