Warning message
QoS on switch
Jul 19th, 2006
I'm installing a set of new switches. Currently we have a voice vlan in our network. My question is, are there any QoS options on the switches, if so how can I use them?
Siwtches: HP/Cisco CGESM Blade modules
CISCO IOS 12.2(25)SED
Thanks for your help.
Dan
zerozerotito Wed, 07/19/2006 - 04:34
Hi dan!
CGESM Blade modules support QoS...
http://h18000.www1.hp.com/products/quickspecs/12164_div/12164_div.html
Well you can use AutoQoS and Standard QoS
Following link will take to configuration guide... It opens slowly so keep your patience...:)
http://www.cisco.com/application/pdf/en/us/guest/products/ps6238/c1067/ccmigration_09186a00805e9035.pdf
Anyhow hope it helps
rafaelgarcia Wed, 07/19/2006 - 18:08
I agree with Dan regarding the Auto QoS implementation. I would be enough for your enviroment if your traffic is not that heavy and it is a great feature.
I talked to a friend of my which is a Cisco Network Design engineer and he told me that Auto QoS needs to be implemented on a clean configuration. Basically you need to erase the configuration of the switch, enable QoS typing mls qos and create each port as a trunk port depending the end device (switch, IP Phone, etc). Otherwise you might find issues with it.
Let me know if it helps.
