Warning message
Creating Attendant Console CorporateDirectory.txt
Jul 22nd, 2006
I faced a problem while creating the CorporateDirectory.txt for the attendant console.
Does anyone has tried to create the file successfully??
The error from the command prompt are as follow:
C:\Program Files\Cisco\CallManagerAttendant\bin>builddir -url ldap://ldap.cisco.
com -searchBase "ou=people, o=cisco.com"
Exception in findAllUsers: com.cisco.ac.server.ldap.ACLdapConnectionException: C
annot connect to directory
Does anyone know that problem is?
Thanks.
Brandon Buffin Sat, 07/22/2006 - 11:54
  • Purple, 4500 points or more
You will need to customize the information to your environment. ldap.cisco.com should be changed to your ldap server. Same thing for searchBase. If you want AC to search a particular OU, replace "people" with that OU. If you want it to search the entire domain, remove ou=x and leave o=domain.com.
Hope this helps. If so, please rate the post.
Brandon
siukai.kwok Sat, 07/22/2006 - 19:18
Thanks for your reply first.
One thing i want to know is....how can i know my url of my ldap server?
The second thing is. when i open the builddir, i found one line is com.cisco.ac.server.ldap.ACBuildUserList, should i change this line or keep it as usual? thx
Brandon Buffin Mon, 07/24/2006 - 04:14
The URL of your ldap server will be in the format ldap:// or ldap://computername.domain.com. As described in the following link, use builddir.bat and it associated parameters to create the corporatedirectory.txt file.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803f3a8b.html#wp1162566
Brandon
