ezvpn doesn't work properly.
Jul 22nd, 2006
I have some problems for configuring ezvpn between router IOS(Client) and VPN3K(Server). I want router to be connected with VPN3K without xauth (that is, without configuring username and password on router).
Topology is following:
VPN3K(public)-(dmz)PIX(outside)-(fa0/0)Router
VPN3K public: 10.10.2.1
PIX dmz: 10.10.2.254
PIX outside: 20.x.2.254
Router fa0/0: 20.x.2.1
ezvpn mode: Client
address pool on VPN3K: 10.10.3.1/32
On VPN3K:
1. IKE proposal: CiscoVPNClient-3DES-MD5
1) authentication mode: preshard (not preshard-xauth)
2. SA: ESP-3DES-MD5
1) IKE Peer: 0.0.0.0
2) Negotiation Mode: Main or Aggressive
3) IKE Proposal: CiscoVPNClient-3DES-MD5
3. Group
1) Name: ezvpn
2) Password: xxx
3) Type: Internal
4. Group-IPSec
1) IPSec SA: ESP-3DES-MD5
2) Tunnel Type: Remote Access
3) Authentication: Internal or None
On Router:
crypto ipsec client ezvpn SJVPN
connect auto
group ezvpn key xxx
peer 10.10.2.1
mode client
interface Loopback0
ip address 20.20.x.x.255.255.0
crypto ipsec client ezvpn SJVPN inside
interface fa0/0
On PIX:
static (dmz,outside) 10.10.2.1 10.10.2.1
access-list outside permit icmp any any
access-list outside permit udp host 20.20.2.1 host 10.10.2.1 eq isakmp
access-list outside permit udp host 20.20.2.1 host 10.10.2.1 eq 4500
access-group outside in int outside
On R1:
ping 10.10.2.1
After completing configuration like the above, ezvpn didn't work properly.
I saw the message like below:
5d16h: ISAKMP (0:9): beginning Aggressive Mode exchange
5d16h: ISAKMP (0:9): sending packet to 10.10.2.1 (I) AG_INIT_EXCH
5d16h: ISAKMP (0:9): retransmitting phase 1 AG_INIT_EXCH...
5d16h: ISAKMP (0:9): incrementing error counter on sa: retransmit phase 1
What's wrong? What should I do?
TIA
andrew100 Tue, 08/01/2006 - 08:38
Just a couple of quick questions to see if i understand the topology. Is your VPN3K Public interface on a private address? Also, did you manually put the loopback address in to the remote router configuration? With EzVPN Client mode the router obtains it's address from the pool configured on the VPN3K, this is the loopback interface created dynamically when the tunnel is built. All traffic then NAT's out on this loopback address. Is this the case?
Andy
