2620 Serial Interface Problem
Jul 24th, 2006
I am receiving the following error from my 2620 after I connect a serial cable between it and a 2501.
"The CD2430 Controller is not responding, power cycle the router"
They are both using PPP encapsulation and the clock rate is set to 64000. I have also rebooted the router as suggested. The interface on the 2620 is a low speed serial. Thanks in advance for any help you can provide.
-Erik
efairbanks Tue, 07/25/2006 - 04:43
Thanks. I actually fixed this last night by reseating the card (yeah...I should have tried that before posting here). Not 100% sure what happened to it. I had everything configured correctly. This router is part of my CCIE lab and I just hope it limps along until I pass. Thanks for your input :)
-Erik
jackyoung Tue, 07/25/2006 - 07:59
  • Gold, 750 points or more
It is great that you fixed the problem and go toward to be a CCIE in future.
