Warning message
Port Spanning
Jul 24th, 2006
I have a group of 3750 switches I need to monitor a few ports on. I have about 4 ports in 3 different vlans I need to monitor. Since the destination port can only be in 1 vlan how would I do this? Would I have to make this a trunk link going to the device on the destination port? Any help is much obliged.
Overall Rating: 5 (1 ratings)
royalblues Mon, 07/24/2006 - 17:29
  • Green, 3000 points or more
When a port is configured as a SPAN destination port, the configuration overwrites the original port configuration.
if all your ports are on the same switch, then you can try the following commands.
eg. source ports 1/1(vlan 2) , 1/2(vlan3) & 1/3(vlan4)
Destination port 1/40
monitor session 1 source interface fa 1/1, fa 1/2, fa 1/3
monitor session 1 destination interface 1/40
refer the following documnet for configuring SPAN on 3750 switches
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00801cdee2.html
Narayan
