How do L2 PDU(BPDU, VTP, CDP) pass through PW between PE?
Answered Question
Jul 24th, 2006
Hi all!
I want to know how L2 PDU(BPDU, VTP, CDP) pass through PW(in AToM) between PE.
CE1--PE1=====PW=====PE2--CE2
Correct Answer by kamlesh.sharma about 11 years 3 weeks ago
Whenever the traffic from CE device enter's into mpls backbone than the complete pdu from CE will be preservered and encapsulated in new format according to forwarding table like if it is etherne than outer header will be ethernet than MPLS lable will be there and than the complete PDU from CE device. and forwarding of the layer two broadcast and multicast has to be done by backbone. in case of BPDU STP and CDP they all have multicast address in the range 01-80-c2-00-00-00 to 01-80-c2-xx-xx-xx they will be tranported accross the backbone to appropriate PE's which are discovered via the sender VE device.
this document will surely help you
http://www.cisco.com/warp/public/121/mpls_packflow.html
please rate if it helps.
Overall Rating: 3.5 (2 ratings)
Correct Answer
kamlesh.sharma Wed, 07/26/2006 - 23:31
