Next Question on ARP with VLANs
Jul 25th, 2006
Here is the scenario... First of all I couldnt try it...
Server---3750---3560---2950---Host1
Server---3750 = This connection VLAN1
3750---3560= VLAN2
3560---2950= VLAN3
2950---Host= VLAN1
Assume that there is router with a trunk port connected to 3560.
Here is the question: Can i see the Host MAC on 3750 ARP Table..
Thanx
Ahmet SAAT
Richard Burts Tue, 07/25/2006 - 07:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Ahmet
There are a couple of things in your scenario that need clarification. You mention that the router to 3560 is a trunk but do not specify the connection of 3560 to 2950. If it is a trunk then things may work but if it is not a trunk there is a big problem. If the connection from the 2950 is not a trunk then the connection from 2950 to host is VLAN 1 and if the 2950 to 3560 is not a trunk then the VLAN 1 traffic can not be forwarded.
If there is a trunk from 2950 to 3560 and a trunk from 3560 to 3750 then there would be VLAN interfaces on the 3750 for each VLAN so that it could do inter-VLAN routing. And in this case the MAC of the host would be in the ARP table of the 3750.
Rick
