How can I configure DHCP server on 4948
jojupj_josep
Pls help me in configuring DHCP server in a Catalyst 4948 switch to deliver Ip's to a particular Vlan and intervlan routing .
jackyoung
Level 6
Level 6
I can't ensure that Cat4k can support DHCP server but it do support DHCP relay. Please check below link for the sample and try to configure it.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1830/products_feature_guide09186a008008743b.html
http://www.cisco.com/en/US/products/ps6021/products_installation_and_configuration_guides_list.html
Please advise if you find any information that indicated Cat4k support DHCP server.
Hope this helps.
Roberto Salazar
Level 8
Level 8
4948 is an IOS based platform that supports L3 functions such as inter-vlan routing. It supports IOS based DHCP server much like a regular router:
DHCP Server on IOS configuration example on the router:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1830/products_feature_guide09186a008008743b.html#25541
ip dhcp excluded-address 172.16.1.100 172.16.1.103
ip dhcp excluded-address 172.16.2.100 172.16.2.103
ip dhcp pool 0
network 172.16.0.0 /16
domain-name cisco.com
dns-server 172.16.1.102 172.16.2.102
netbios-name-server 172.16.1.103 172.16.2.103
netbios-node-type h-node
ip dhcp pool 1
network 172.16.1.0 /24
default-router 172.16.1.100 172.16.1.101
lease 30
ip dhcp pool 2
network 172.16.2.0 /24
default-router 172.16.2.100 172.16.2.101
lease 30
Please rate helpful posts.
