ariela Wed, 07/26/2006 - 05:33
  • Silver, 250 points or more
Example:
192.168.11.0/24
-> 192.168.11. 0|0000000 >> 192.168.11.0/25
-> 192.168.11. 1|0000000 >> 192.168.11.128/25
192.168.11.128/25
-> 192.168.11. 10|000000 >> 192.168.11.128/26
-> 192.168.11. 11|000000 >> 192.168.11.192/26
192.168.11.192/26
-> 192.168.11. 110|00000 >> 192.168.11.192/27
-> 192.168.11. 111|00000 >> 192.168.11.224/27
192.168.11.224/27
-> 192.168.11. 1110|0000 >> 192.168.11.224/28
-> 192.168.11. 1111|0000 >> 192.168.11.240/28
192.168.11.240/28
-> 192.168.11. 11110|000 >> 192.168.11.240/29
-> 192.168.11. 11111|000 >> 192.168.11.248/29
192.168.11.248/29
-> 192.168.11. 111110|00 >> 192.168.11.248/30
-> 192.168.11. 111111|00 >> 192.168.11.252/30
192.168.11.252/30
-> 192.168.11. 1111110|0 >> 192.168.11.252/31
-> 192.168.11. 1111111|0 >> 192.168.11.254/31
that's just an example ... Improuve your subnetting ;)
Andrea
carl_townshend Wed, 07/26/2006 - 07:31
wow, thanks for that, is there a table you can work this out on ? so can you use all them networks at once on the same site, and they are all represented by the /24 ?
