Warning message
denying TFTP on 6500 Cat
Jul 27th, 2006
recently we had a pen test against one of our Cats and it failed with an open port 69/udp open tftp. As a result I had to apply an ACL to the interface. We do not have TFTP-server configured on this Cat or any other cats on our platform but the Security Engineer claims that we must have some TFTP service running on this Cat as has never seen this failure before. My argument and question is that the CAT interface will always reply to port 69 regardless of whether we have TFTP server configured or not and the only way to stop an interface replying to port 69 is to add an acl. Which one of us is correct ?
andrew.burns Fri, 07/28/2006 - 01:11
  • Gold, 750 points or more
which cat and ios revision is it?
Andrew.
andrew.burns Fri, 07/28/2006 - 01:38
by default tftp is disabled, so unless you have a "tftp-server" command in your config it's hard to believe that udp/69 would be open.
You can easily check which ports are open by doing a "show ip socket" command - it's more likely that udp/67 will be open...
Andrew.
r.dell Fri, 07/28/2006 - 02:35
I agree and a 'show IP socket' reveals that port 69 nor 67 are running but the question still remains would a poll against an open interface on port 69 get a responce ?
This is the test performend by the security eng.
[email protected]-Box:~# nmap -sU -n -vv 172.16.139.189 -vv -p 69 -v
Starting nmap 3.75 ( http://www.insecure.org/nmap/ ) at 2006-01-05 10:09 GMT
Initiating UDP Scan against 172.16.139.189 [1 port] at 10:09
Discovered open port 69/udp on 172.16.139.189
The UDP Scan took 0.00s to scan 1 total ports.
Host 172.16.139.189 appears to be up ... good.
Interesting ports on 172.16.139.189:
PORT STATE SERVICE
69/udp open tftp
andrew.burns Fri, 07/28/2006 - 04:21
In answer to your question, I would have thought that you should definitely not had a response, unless you are specifically running a tftp server. Do you see a tftp demon running in the "show process" output?
Andrew.
