Warning message
Web VPN does not forward RDP (TCP/3389) to remote destination
When connecting "From" a WinXP workstation (with RDP enabled) through WebVPN, An RDP connection appears to contact the local machine instead of the remote host. All other protocols work fine (SSH, Telnet, SQL)
Turning off RDP on the XP workstation seems to work around the issue but is there a way for the Java applet to forward TCP/3389 without having to disable Remote Desktop locally?
I have the port forwarding setup as follows on the config page of the concentrator:
Name: SERVER01 - RDP
Local TCP port: 63389 (have tried others)
Remote Server: server01.domain.com
Remote TCP port: 3389
Concentrator: 3015
OS Ver: 4.7.2.D
Colin Bell
SISD Network Admin
