Configuring Catalyst 2950
Jul 28th, 2006
Hi Collegue,
My CallManager and ip phones are in placed.
I have a Catalyst 2950 ONLY available in my lab.
CallManager and IP phones are attached to my 2950. DHCP server is also configured in my Callmanager.
If I attached my IP phones how can I configure my 2950 to get the IP address in my call manager.
Please be advised.
Overall Rating: 3 (1 ratings)
Bobby Thekkekandam Fri, 07/28/2006 - 06:54
  • Cisco Employee,
Are you asking how you can configure the 2950 to receive a DHCP address from the callmanage?
thanks,
Bobby
royalblues Fri, 07/28/2006 - 08:00
  • Green, 3000 points or more
Jhun,
THere is no configuration required on the 2950.
I assume that your IP phones and Call Manager are in common IP schema.
Just plug the phones and they should be getting the IP
However if you want the Auxillary VLAN feature .e connecting a phone and PC to the same port you ahve to configure voice vlan
eg (data =vlan 2 and voice =vlan 3)
(config)#switchport access vlan 2
(config)#switchport voice vlan 3
Narayan
JUNKSA_2 Fri, 07/28/2006 - 11:41
Hi Narayan,
see the config:
interface vlan 20
ip address 192.168.1.2 255.255.255.0
ip helper-address 192.168.1.5
no shut
config#interface fastethernet 0/17
config#switchport access vlan 20
config#spanning tree-portfast
config#
I try this configuration but nothing happen. Do I missed any configuration or the configuration is wrong?
Please be advised.
JUNKSA_2 Fri, 07/28/2006 - 11:30
Hi Bobby,
Yes,I already configured the CallManager and I also run the DHCP server on the same machine.
I dont understand why all the IP phones is not getting any IP from the DHCP.
The CallManager and the IP Phones are attached in the same 2950 switch.
I created vlan 20 (Voice) see the configuration below:
interface vlan 20
no shut
interface vlan1
no ip address
shutdown
**** port 1 and 2 are my call manager servers
**** port 17 to port 20 are the IP Phones
see the configuration for the port:
spanning tree portfast
I dont know if there is something missing or wrong in my configuration.
Can you help me to sort it out the problem.
Thanks.
globalnettech Fri, 07/28/2006 - 11:57
  • Silver, 250 points or more
sorry for the confusion: the 2950 cannot do any layer 3 routing, so your VLAN 20 interface is for management only. Which VLAN are the call manager servers in ? If you have only the 2950, put all devices/switchports in the same VLAN.
Can you post the entire configuration of your 2950 ?
GNT
JUNKSA_2 Fri, 07/28/2006 - 20:48
You are right I was totally confused, I know that 2950 is a layer 2 switch only and cannot do routing.
I put all the devices in the same vlan without any configuration in the switchport and it works.
Thanks for the advise.
