Warning message
Apply QOS to vrf traffic?(Ethernet SubInts)
Jul 30th, 2006
I'm trying to apply "GOLD" QOS to vrf traffic that is terminated on eth subints, but class-map is not allowing me to match on subinterfaces:
class-map match-any GOLD
match mpls experimental topmost 5
match ip precedence 5
match input-interface fastEthernet 0/0 (Subints not allowed)
I also cannot match on access-group, as the traffic is within a vrf.
Should I be creating a seperate policy-map marking the traffic as GOLD, and then apply this as a "service-policy input" to each eth subint the vrf is associated with?
Overall Rating: 4 (2 ratings)
thomas.chen Fri, 08/04/2006 - 05:36
  • Silver, 250 points or more
Yes,after creating the class map ,specify this class under the policy map and indicate the action.Afterwards,you can apply this policy to interface.
mheusinger Fri, 08/04/2006 - 06:59
  • Green, 3000 points or more
when you apply the service-policy to an interface you do NOT need to specify the interface in the class-map! Example:
class-map match-any VoIP
match ip dscp ef
policy-map Marking
class VoIP
set mpls experimental imposition 5
interface FastEthernet0/0.100
ip address ...
encapsulation dot1q 100
service-policy input Marking
This will set MPLS exp bits on all traffic coming into F0/0.100 and being marked with either Prec 5 or DSCP EF.
Sidenote: using an ACL in class VoIP will also only match traffic on the interface, where the policy is applied. So overlapping customer addresses are not an issue.
Hope this helps! Please rate all posts.
Regards, Martin
johnelliot Fri, 08/04/2006 - 13:35
Thanks guys - I also assume we will need some form of admission control on every customer facing int(To ensure those not paying for "gold" class, can't classify there egress traffic as they see fit ;) )
eg.
Customers not buying any QoS, have a "set ip dscp 0" class-default
inbound policy-map.
mheusinger Sat, 08/05/2006 - 02:25
Very true!
To my knowledge it is called precedence spoofing. This is f.e. why in all Cisco LAN switches all ports are defaulting to "untrusted" i.e. they rewrite cos/DSCP to 0.
You might also need a policer, which limits the customer, who bought "GOLD" to the speed purchased. Remark excess traffic to 0, but do not drop it, because then he might get the feeling that his "GOLD" traffic is treated worse (discards experienced) than best effort (possibly no discards if enough bandwidth).
Regards, Martin
mazlan484106 Tue, 08/29/2006 - 19:49
I cannot using hyper terminal to link between Router and my laptop,could someone help to this problem.
