Warning message
Port forward/VPN conflict
Aug 1st, 2006
I've created a site-site VPN between two 877s using the easy site-site VPN option in the SDM.
Users in the remote office will be using terminal services to access a server in the head office. It is also required that users can access the terminal server across the internet.
My problem is that whenever I enter the command to have the necessary ports forwarded to the internet, I then cannot connect to those ports over the VPN.
The command I use to port forward is "ip nat inside source static tcp 10.0.2.202 3389 interface Dialer0 3389"
Any help with this is greatly appreciated. If you need more info please let me know. I assume this is a fairly common problem?
TIA,
-A
irisrios Mon, 08/07/2006 - 08:35
  • Silver, 250 points or more
Check whether any ACL's are there in the configuration which blocks the traffic
