Warning message
7970 Firmware CCME 3.2
Aug 3rd, 2006
Hi, I'm configuring a CallManager Express 3.2. I'm installing two types of IP Phones: 7940G and 7970G. I haven't could find the firmware for the 7970G IP Phone for this version of CallManager Express. Thanks.
Brandon Buffin Thu, 08/03/2006 - 08:34
  • Purple, 4500 points or more
Depending on the release of 3.2 that you're using, you can either use 6.0(3)SR1 or 7.0(1). Both can be found here:
http://www.cisco.com/cgi-bin/tablebuild.pl/ip-iostsp
Also, take a look at this link regarding configuring the 7970 with CME 3.2.1.
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a008042326b.shtml
Hope this helps. If so, please rate the post.
Brandon
hernan.lopez Thu, 08/03/2006 - 10:15
Thanks for your help. This CallManager Express doesn't have any release, the version is 3.2. I just tried to use firmware for CCME 3.2.1, however it doesn't work. If you have other suggestion, please send it to me.
Brandon Buffin Thu, 08/03/2006 - 11:11
On the router, type "show telephony-service". You should see your version at the top.
Brandon
