Warning message
VTP configuration is not in show run
Aug 4th, 2006
On a Catalyst 4506, where can I see the VTP saved configuration (VTP mode, VTP Domain name,...)? In which file ? Or with which command ?
Because show run does not make it appear !
And the VLAN config also ?
Thank you
Patrice
Overall Rating: 4.5 (5 ratings)
mheusinger Fri, 08/04/2006 - 03:13
  • Green, 3000 points or more
the vtp stuff is not in the running config, but in the vlan.dat in flash.
Use "show vtp status" to see what the current status of your switch is.
Switch#show vtp status
VTP Version : 2
Configuration Revision : 12
Maximum VLANs supported locally : 250
Number of existing VLANs : 13
VTP Operating Mode : Client
VTP Domain Name : MyVTP1
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0xCB 0x1E 0xF2 0x66 0xE4 0x67 0xCD 0x57
Configuration last modified by 0.0.0.0 at 3-2-93 17:02:57
show vtp password
sh vtp counters
VTP statistics:
Summary advertisements received : 76
Subset advertisements received : 27
Request advertisements received : 0
Summary advertisements transmitted : 71
Subset advertisements transmitted : 22
Request advertisements transmitted : 0
Number of config revision errors : 1
Number of config digest errors : 0
Number of V1 summary errors : 0
VTP pruning statistics:
Trunk Join Transmitted Join Received Summary advts received from
non-pruning-capable device
Fa0/1 0 0 0
Fa0/2 0 0 0
Hope this helps! Please rate all posts.
Regards, Martin
farkascsgy Fri, 08/04/2006 - 03:44
  • Silver, 250 points or more
VLAN related configurations are stored in vlan.dat file.
For example:to set the VTP domain name to NULL (factory default) you can do this only with deleting the vlan.dat file. (it's a binary file not text)
And also show vlan command is useful to check the VLAN database...
bye
FCS
Please rate me if I helped.
p.tavan Fri, 08/04/2006 - 04:40
Martin,
Thank you, but when I do : show bootflash, I think I do not see the file vlan.dat,do you know why ?
Patrice
farkascsgy Fri, 08/04/2006 - 04:55
Check the flash the vlan.dat should be there...
bye
FCS
p.tavan Fri, 08/04/2006 - 05:20
OK, I will look more precisely, thank you FCS.
Patrice
Roberto Salazar Fri, 08/04/2006 - 10:20
  • Gold, 750 points or more
You will not find vlan.dat on this platform on bootflash: or flash: or nvram:. It's in the cat4000_flash: file directory:
cat4000# dir ? >>> you should see all the filesystem directory. And you should see "cat4000_flash:", if you then do this:
cat4000#dir cat4000_flash:
Directory of cat4000_flash:/
1 -rw- 2116 vlan.dat
524280 bytes total (522164 bytes free)
To copy it to tftp server:
cat4000#copy cat4000_flash:vlan.dat tftp
Address or name of remote host []? 10.1.1.1
Destination filename [vlan.dat]?
As you can see above it's in the cat4000_flash:, that's NOT flash or bootflash or nvram.
Please rate the posts if it helped or resolve this issue.
p.tavan Sat, 08/05/2006 - 12:45
Bosalaza,
Thanks a lot, because effectively it does not appear in bootflash.
Patrice
