Warning message
extended ping data patterns defined
Aug 4th, 2006
I am looking for information on data patterns used while performing extended pings.
So far this is all I can find:
0xffff = repeater power problems
0x0000 = line code mismatches
0x4040 = timing problems.
0x5555 = The alternating pattern represents a "typical" data pattern
Are these accurate and are there any more data patterns I can test with?
dan_sharp Wed, 08/09/2006 - 06:56
What are you pinging across? A frame relay set up or? Will depend on what patterns are worthwhile for each case.
