Warning message
CNA config files?
Answered Question
Aug 4th, 2006
I want to move my communities from one CNA to another CNA program. Is there a config file to copy?
Also why do they put a limit one the devices? Why not just keep using a cluster? They both limit the same amount.
Correct Answer by aazim about 11 years 5 days ago
Your community files are located at the following directory:
\Documents and Settings\Username\.networkassistant\communities
Please replace the username with your own username.
You can copy the community files and copy it to the same location on a different PC.
Ajang
Overall Rating: 5 (1 ratings)
mchin345 Fri, 08/11/2006 - 05:18
  • Silver, 250 points or more
The total number of devices in the community does not exceed 20 total devices (including up to 4 Catalyst 4500 series switches (modular), 16 Catalyst 2900/3500 or Catalyst 4948 switches (non-modular), 2 routers, and 12 access points). For more info refer
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_configuration_guide_chapter09186a00803b6e33.html#wp1078524.
Correct Answer
aazim Tue, 08/15/2006 - 18:11
Ajang
