SFP Port Disabled?
IM-Design
Hi I have a link between:
Switch A (3750G PS48)
and
Switch B (2 stacked 3750G TS24)
These are connected via fiber through their SFP ports using the SFP GLC-SX-MM tranceivers.
On Switch A, one of the SFP ports (poort 50) indicates that it is disabled from the Cisco Device Manager web page and it is showing an amber light.
On switch B, both SFP ports have green LEDs.
Any ideas on how to enable this port?
9 Replies 9
farkascsgy
Level 4
Level 4
Did you checked the status of the port from command line? show interface "port"
If this is in shutdown stat just add no shutdown and the port is enabled...(in this case on the other end is not green)
bye
FCS
Please rate me if I helped.
Not able to do a show interface "port" for ports 49 and 50 (dont know why). Is it because these are SFP ports?
Anyway, I did a show interface and shown below is the output for 49 and 50. 49 is showing greed, while 50 is amber:
GigabitEthernet1/0/49 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0016.c7f7.a831 (bia 0016.c7f7.a831)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
input flow-control is off, output flow-control is unsupported
Last input 00:00:01, output 00:00:17, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 1 packets/sec
5 minute output rate 1000 bits/sec, 1 packets/sec
83696 packets input, 15488039 bytes, 0 no buffer
Received 46220 broadcasts (0 multicast)
0 watchdog, 30403 multicast, 0 pause input
162927 packets output, 71484021 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
GigabitEthernet1/0/50 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0016.c7f7.a832 (bia 0016.c7f7.a832)
Keepalive not set
Last input 00:00:00, output 00:00:23, output hang never
118803 packets input, 9003642 bytes, 0 no buffer
Received 118281 broadcasts (0 multicast)
0 watchdog, 113959 multicast, 0 pause input
29254 packets output, 10447720 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Any ideas?
There is no command such as "show interface port" which is why you can't do it, you can't do that command on any of the ports, it's "show interface gig x/y/z". Now, the "port" or interface is amber because it's most likely in blocking state - 49 and 50 are probably connected to the same switch. How can you check if it's in "blocking" mode?
sh spanning-tree blockedports
sh spanning-tree interface gig 1/0/50
http://www.cisco.com/univercd/cc/td/doc/product/wireless/c3750wlc/hig/higoverv.htm#wp1134782
Table 1-7 Meaning of LED Colors in Different Modes on the Switch
Amber
Port is blocked by Spanning Tree Protocol (STP) and is not forwarding data.
Note: After a port is reconfigured, the port LED can remain amber for up to 30 seconds as STP checks the switch for possible loops.
Please rate this post if it helped.
Thanks for the reply,
That helped. At least I now know that the port is blocking. Here is the ourput from those commands:
switch404#sh spanning-tree blockedports
Name Blocked Interfaces List
VLAN0001 Gi1/0/50
Number of blocked ports (segments) in the system : 1
switch#sh spanning-tree interface gig 1/0/50
Vlan Role Sts Cost Prio.Nbr Type
VLAN0001 Altn BLK 4 128.50 P2p
switch#
Now, what do I need to do to unblock?
etherchannel
you need to understand STP, at current STP situation, I don't think you want to unblock it. It is not blcking because it's broken or anything, the STP is protecting you from a loop.
Please rate helpful posts.
OK (thanks),
I understand that you are saying that this blocking is by design. We have redundant fiber linking 5 switches, so it makes some sense to me that 2 of the switches have a blocking port as the nominal situation.
Would you be able to point me to a document for better understanding of STP.
Here you can read some details:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_white_paper09186a0080094cfa.shtml
bye
FCS
here's a good link for all spanningTree flavors:
http://www.cisco.com/en/US/tech/tk389/tk621/tsd_technology_support_protocol_home.html
look in the 'configuration examples and techNotes' for 'understanding stp' guides.
