Unity GDM questions
Aug 7th, 2006
When setting up a GDM, how do you configure this to light up the MWI on different phones? For example, GDM is extension 499, which isn't bound to any phone. I would like to light the MWI on phones 400 and 401 when there is a message in the GDM.
Overall Rating: 5 (1 ratings)
thisisshanky Mon, 08/07/2006 - 13:26
  • Purple, 4500 points or more
1. Create a Callhandler CH with the number 499.
2. Create a PDL with members 400 and 401.
3. Set schedule of CH to all days all week if you want it 24 * 7.
4. Set the transfer settings on CH to go to Greeting (Default).
5. Set the greeting (use TRAP to record the greeting).
6. If you dont want caller input while the greeting for CH is played, uncheck it.
7. After greeting take message.
8. Under messages option in the Callhandler, set the message recipient to the PDL you created in step 2.
Sankar
PS: please remember to rate posts!
