Warning message
Unable to move vsan and zone information accross a trunk
Aug 7th, 2006
Folks,
I am new to MDS. I have 3 SAN switches (9516). I connected both of them using fc 1/7, i created vsans and zoneset on one switch, but was unable to propogate the information to the other switch. I enable EISL between the 2 switches on port fc 1/7? also when i type in "show fcs application" it shows me the vsan is disabled?
Application Enabled Scope
ivr Yes Physical
ntp No Physical
dpvm Yes Physical
role No Physical
vsan No Physical
radius No Physical
syslogd No Physical
callhome No Physical
device-alias Yes Physical
Total number of entries = 9
How can i propagate vsan information and zoneset information accross fabric or switches?
Overall Rating: 5 (1 ratings)
dmcloon Tue, 08/08/2006 - 00:54
  • Bronze, 100 points or more
Make sure the same VSAN number is created on both switches. Make sure there are no zone member conflicts or domain ID overlaps.
Do not worry about the cfs output. The "vsan" in this context means cfs distribution of per vsan FC timers such as FS_TOV. You must be running an early 2.x release because we have since renamed this to "fctimer" under cfs apps.
Please see the Config Guide for more info, it is your best resource especially if you are new to MDS.
http://www.cisco.com/univercd/cc/td/doc/product/sn5000/mds9000/3_0/fmcfg/index.htm
The Troubleshooting Guide as well,
http://www.cisco.com/univercd/cc/td/doc/product/sn5000/mds9000/3_0/ts/index.htm
Trending Topics: Storage Networking
