Warning message
Regarding VPN
Aug 7th, 2006
Hi Guys,
I have Configured a site-to-site VPN tunnel between pix and VPN 3015
here the problem is the PIx at the remote end doesn't have the public ip .I have terminated the Tunnel at the DSL modem
the tunnel was established and the Data traffic also happens but after 30min or
i hour any one of the IPsec tunnel will not work
i have defined 5 ACl's in there 3 is always accessable (3 Networks)
2 is giving problem
if reboot the pix then every thing will work for 30-45 min then the same problem.
even i have reduced the IPsec lifetime
to 3600 sec
but nothing happens
at last i have decided to Configure the pix and Concentrator as given in the Attached Document
My question is if configured like that does it affcet my exsisting VPn users? (Remote VPN)
Please advice
krishna.
