Warning message
VPN 3000 Console Connection
Answered Question
Aug 8th, 2006
I have vpn3005 concentrator in the office. I have used the specially made console cable. But when I tried to connect it to my terminal Server (C2511) I cannot get any output. I used a DB9/RJ45 adaptor and plug it on to the Octal cable from Term Server. Is there a solution to this?
Respectfully,
Lorenz
Correct Answer by hunter-killer about 11 years 1 week ago
A straight-through cable with a DB9 terminal adapter on each end is what the console cable is what I use with the VPN3030s
Overall Rating: 4 (2 ratings)
pradeepde Fri, 08/11/2006 - 09:18
  • Bronze, 100 points or more
1.Check the physical connectivity whether the cable used are good condition or not.
2.Replace it with another working cable and check to connect
Richard Burts Sun, 08/13/2006 - 16:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I believe that the octal cable from the C2511 is a roll-over cable. I believe that the connection to the concentrator should be a straight through. Can you get an async connection from a terminal server that is not through the octal/roll-over cable? Or perhaps can you connect a roll-over cable to the octal cable (rolling it twice produces straight?)?
Rick
l.tating Sun, 08/13/2006 - 17:23
Hi Rick,
I will try to connect another roll-over to the octal, via a DB9 Male. I cannot see any documentation in CCO that tells the exact description of the console cable that comes with all VPN3000s.
Lorenz
Correct Answer
hunter-killer Mon, 08/14/2006 - 07:04
