NAT external to internal
geoffalbin
i am having trouble with NAT. it is my first try at this and need some help, please. I have a 2610 with 2 Fastethernet connections. fa1/0 is internal 10.10.10.1/24
fa0/0 is external 66.73.xx.xx/26
i can succsefully go internal out to external with the ip nat inside source list 1 int fa0/0 overload command.
what is the command to allow external to internal. thanks
ip nat inside source static 10.10.10.10 66.73.xx.xx will give you a full translation bi-directional
5 Replies 5
mmeiers
What is an example of what you are trying to do? Send traffic to a web server or something?
tcp port 5900 for vnc is one thing.
I think these should help depending on your exact scenario.
Static NAT
ip nat inside source {static {esp local-ip interface type number | local-ip global-ip}} [extendable | mapping-id map-id | no-alias | no-payload | redundancy group-name | route-map | vrf name]
no ip nat inside source {static {esp local-ip interface type number | local-ip global-ip}} [extendable | mapping-id map-id | no-alias | no-payload | redundancy group-name | route-map | vrf name]
Port Static NAT
ip nat inside source {static {tcp | udp {local-ip local-port global-ip global-port | interface global-port}} [extendable | mapping-id map-id | no-alias | no-payload | redundancy group-name | route-map | vrf name]
no ip nat inside source {static {tcp | udp {local-ip local-port global-ip global-port | interface global-port}} [extendable | mapping-id map-id | no-alias | no-payload | redundancy group-name | route-map | vrf name]
Here is the link to the doc for NAT for more details on NAT
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hiad_r/adr_i2h.htm#wp1178184
i wish i could say this is helping, however, it is not. i guess i just need a way to NAT 66.73.xx.xx into 10.10.10.10
