Warning message
pre2 with minor alarm
Aug 9th, 2006
hi,
I got a ubr10k with pre2 with processor. But i always see the minor led is lighting. I check the temperture is fine. Could anyone know the meaning of the alarm ?
best regards.
fred
jackyoung Wed, 08/09/2006 - 23:03
  • Gold, 750 points or more
I did not use UBR before, but checked some info. in CCO. Please check below if if can help. Accordinf to the link, this is an informational alarm and does not affect the system operation.
http://www.cisco.com/univercd/cc/td/doc/product/cable/ubr10k/ubr10012/hig/u10kinst.htm#wp1039019
Did you get any log from the router ? Try to use "show facility-alarm status" to check it. Check below for more info.
http://www.cisco.com/univercd/cc/td/doc/product/cable/ubr10k/ubr10012/hig/u10ktrb.htm
Hope this helps.
