can any one tell me what different between VACL and ACL with ip access-goup
SZU CHI CHEN
Dear all
Environment Cisco 3550 Switch
pls support
tks
SZU CHI CHEN
can any one give advice
which is suitable when access-list apply in vlan not L3 port
and why select
tks for your kind
Hi Jason
The VACL configuration in Cisco IOS is based on the traditional IOS ACL implementation. That is, it relies on the IOS access-list command to define the traffic matching parameters. From there, all configuration (including ACL reference and action) is done from the "vlan access-map" configuration mode. (may see http://www.cisco.com/en/US/products/hw/switches/ps708/products_white_paper09186a00800c8441.shtml)
M
hi matthew
tks
Dear all expert
still need input some comment
tks for your kind
