Warning message
Unity
Aug 10th, 2006
I have a Unity fail over box and I need to change the IP and Hostname.
I think that the ip is easy just chage it. With the hostname it is a little more complicated.
I guess I should remove it from the domain and then change the name and IP and add it back to the domain.
Any help would be welcome
kdamisch Thu, 08/10/2006 - 23:11
Here are a couple of links that may help you.
Changing IP address of Unity server:
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps2237/products_tech_note09186a0080094a69.shtml
Renaming the Cisco Unity server:
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps2237/products_maintenance_guide_chapter09186a00801c1ec0.html#1073520
As usual, make sure you have a backup when making these kinds of changes.
Hope this helps! If so, please rate.
Kevin
