Warning message
ASA 5520 permit dns through firewall
Aug 11th, 2006
i have a box that sits in my DMZ that i can't get dns resolution from an internal dns server on our internal network, ip 192.168.1.8
i am having trouble get the requests through the fire, any help would be appreciated
below is my config
interface GigabitEthernet0/0
description Inside Interface
nameif Inside
security-level 100
ip address 192.168.1.254 255.255.255.0
interface GigabitEthernet0/1
description DMZ interface
nameif DMZ
security-level 0
ip address 10.10.50.1 255.255.255.0
access-list dmz extended permit ip host 10.10.50.20 any
access-list dmz extended permit tcp host 10.10.50.20 192.168.1.0 255.255.255.0 eq 8443
access-list dmz extended permit ip host 10.10.50.20 host 192.168.1.4
access-list dmz extended permit tcp host 10.10.50.20 host 192.168.1.4 eq smtp
access-list dmz extended permit tcp host 10.10.50.20 host 192.168.1.4 eq pop3
access-list dmz extended permit ip host 10.10.50.50 any
access-list dmz extended permit ip host 10.10.50.50 192.168.1.0 255.255.255.0
access-list dmz extended permit tcp host 10.10.50.50 192.168.1.0 255.255.255.0 eq 3389
access-list dmz extended permit udp 10.10.50.0 255.255.255.0 host 192.168.2.8 eq domain
access-list dmz extended permit udp 10.10.50.0 255.255.255.0 host 192.168.1.8 eq domain
access-list outside_in extended permit icmp any any
access-list outside_in extended permit udp any eq domain any
access-list outside_in extended permit tcp any host xxxxxxxxx eq www
access-list outside_in extended permit tcp any host xxxxxxxxx eq https
access-list outside_in extended permit tcp any host xxxxxxxxx eq pptp
tcp-map mss-map
exceed-mss allow
pager lines 24
logging enable
logging monitor informational
logging asdm informational
mtu Inside 1500
mtu DMZ 1500
mtu Outside 1500
mtu management 1500
no failover
icmp permit any Inside
icmp permit any DMZ
icmp permit any Outside
asdm image disk0:/asdm512-k8.bin
no asdm history enable
arp timeout 14400
global (Outside) 1 interface
nat (Inside) 1 192.168.1.0 255.255.255.0
nat (Inside) 1 192.168.0.0 255.255.0.0
nat (DMZ) 1 10.10.50.0 255.255.255.0
Overall Rating: 2 (1 ratings)
a.kiprawih Sat, 08/12/2006 - 08:17
  • Gold, 750 points or more
How about resolution from 192.168.2.8? is it ok? BTW, how's the access from DMZ to inside? Can you share other remaining config info such as static, etc?
The statement ACL looks ok for DMZ to access inside host.
Rgds,
AK
dbakula01 Mon, 08/14/2006 - 04:58
nameif Inside
security-level 100
nameif DMZ
security-level 0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
description Outside Interface for our Expediant Line
nameif Outside
security-level 0
ip address xxxxxxxxxx 255.255.255.240
interface Management0/0
nameif management
security-level 100
no ip address
management-only
passwd xxxxxxxxxx encrypted
ftp mode passive
dns server-group DefaultDNS
domain-name xxxxxxxxxx
same-security-traffic permit inter-interface
access-list CSC extended permit ip any any
access-list Outbound_ACL standard permit any
access-list dmz extended permit udp 10.10.50.0 255.255.255.0 192.168.0.0 255.255.0.0 eq 1031
access-list dmz extended permit icmp any any
access-list dmz extended permit udp 10.10.50.0 255.255.255.0 192.168.0.0 255.255.0.0 eq domain
access-list outside_in extended permit tcp any host xxxxxxxxxx eq www
access-list outside_in extended permit tcp any host xxxxxxxxxx eq https
access-list outside_in extended permit tcp any host xxxxxxxxxx eq pptp
tcp-map mss-map
exceed-mss allow
pager lines 24
logging enable
mtu Inside 1500
mtu DMZ 1500
mtu Outside 1500
mtu management 1500
no failover
icmp permit any DMZ
arp timeout 14400
static (Inside,Outside) xxxxxxxxxx 192.168.1.4 netmask 255.255.255.255
static (Inside,DMZ) 192.168.1.0 192.168.1.0 netmask 255.255.255.0
static (DMZ,Outside) xxxxxxxxxx 10.10.50.50 netmask 255.255.255.255
static (DMZ,Outside) xxxxxxxxxx 10.10.50.20 netmask 255.255.255.255
access-group dmz in interface DMZ
access-group outside_in in interface Outside
route Inside 192.168.0.0 255.255.0.0 192.168.1.1 1
route Outside 0.0.0.0 0.0.0.0 207.54.182.49 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
username admin password mKYTG3oCAANq6D8j encrypted
http server enable
http 192.168.1.0 255.255.255.0 Inside
http 192.168.1.0 255.255.255.0 management
snmp-server host Inside 192.168.1.185 community xxxxxxxxxx
no snmp-server location
no snmp-server contact
snmp-server community hostdcp1191
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet 192.168.1.0 255.255.255.0 Inside
telnet timeout 20
ssh 192.168.1.0 255.255.255.0 Inside
ssh timeout 60
console timeout 0
dhcpd lease 3600
dhcpd ping_timeout 50
class-map dns-port
match port udp eq domain
class-map CSC-class
match access-list CSC
a.kiprawih Tue, 08/15/2006 - 01:01
Try add the following static map for the DMZ to inside segment running 192.168.2.0/24.
The current static see below) allows your DMZ to access the DNS is 192.168.1.0/24 segment, but no access (no static map) to 192.168.2.0/24.
static (Inside,DMZ) 192.168.1.0 192.168.1.0 netmask 255.255.255.0 --> ok
static (Inside,DMZ) 192.168.2.0 192.168.2.0 netmask 255.255.255.0 --> add this..
Rgds,
AK
a.kiprawih Tue, 08/15/2006 - 01:33
Pls ignore the above post as I have mistakenly point to wrong solution.
Since the issue was only involving a single box/host in your DMZ, can other hosts talk to the DNS server (192.168.1.8)?
The static map "static (Inside,DMZ) 192.168.1.0 192.168.1.0 netmask 255.255.255.0" allows your whole DMZ to talk to Inside hosts without address translation, and this should work with the whole subnet.
If only one (1) host is affected, then it might be issue with the host itself. I did not see any ACL denying specific host talking to the 192.168.1.8.
BTW, do you see any deny statement in the firewall log when that particular host tries to resolve/communicate with the DNS server?
Rgds,
AK
