Warning message
1605R Router help
Aug 12th, 2006
I am using a cisco 1605R Router, I do not have any documents for it, I need to access one my PCs from outside using an IP address.
How can i access the router from one of PCs and how do I program the router to direct the incoming IP (static) to a particular PC in my network.
I do not have physical access to the Router. (hard to reach)
Thank you.
Overall Rating: 4 (1 ratings)
desai.jaideep Sat, 08/12/2006 - 22:48
  • Gold, 750 points or more
First of all you need to set the internal PC as RDP or VNc server.
Below is the config I have been doing:It is basically a LAB setup in which I have public IPs 192.168.1.0/24 and private IPs 192.168.2.0/24.Now I am giving 192.168.1.165/24 on one serial and 192.168.2.1/24 on another ethernet.I have kept a webserver (a Ip camera with a web server..to be precise), which is given a IP 192.168.2.200/24. Now from pool 192.168.1.0 (My PC ip is 192.168.1.75/24) I give 192.168.1.165 in my web browser, and I get access to my network camera.
interface serial0/0
ip address 192.168.1.165 255.255.255.0
ip nat outside
interface FastEthernet0/1
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip nat pool test 192.168.1.165 192.168.1.165 netmask 255.255.255.0
ip nat inside source list 1 pool test overload
ip nat inside source static 192.168.2.200 192.168.1.165
ip classless
access-list 1 permit 192.168.2.0 0.0.0.255
Router#sh ip nat translations
Pro Inside global Inside local Outside local Outside global
tcp 192.168.1.165:80 192.168.2.200:80 192.168.1.75:1197 192.168.1.75:1197
tcp 192.168.1.165:80 192.168.2.200:80 192.168.1.75:1200 192.168.1.75:1200
tcp 192.168.1.165:80 192.168.2.200:80 192.168.1.75:1201 192.168.1.75:1201
tcp 192.168.1.165:80 192.168.2.200:80 192.168.1.75:1202 192.168.1.75:1202
tcp 192.168.1.165:80 192.168.2.200:80 192.168.1.75:1203 192.168.1.75:1203
tcp 192.168.1.165:80 192.168.2.200:80 192.168.1.75:1204 192.168.1.75:1204
--- 192.168.1.165 192.168.2.200 --- ---
You will be access the internal PC from the Internet.
Pls rate helpful posts
JD
