Warning message
TTS Nuance Vocalizer 4 and IPCC Express 4.04 integration
Aug 12th, 2006
Had purchased Nuance Vocalizer 4 10 ports license and download all software along MRCP.
IPCC Express 4.04 premium running on the same server.
1. get Nuance Vocalizer to run without MRCP, TTS subsystem up, but no TTS audio.
2. Install MRCP, but cannot get Vocalizer to run, TTS subsystem down.
Not much help from syntellect. Any help will greatly appreciated.
Thanks...
karlroberts Wed, 08/16/2006 - 08:27
Hi, We have it all running fine in lab and customer sites!
What Nuance version are you running. Should be v8.5 SP10 the last time I checked.
the MRCP server should be installed first, and you need to make sure your Nuance MRCP have the correct settings in the language map and startup batch file. Then you add TTS language model and vocalizer.
Never really had problems! Drop us a mail at [email protected] and I'll do my best to help if your still stuck
Karl
Karl Roberts, JAM IP, UK
Advanced Contact Services (inc Speech)
