Warning message
switchport mode access
Answered Question
Aug 13th, 2006
what is the use of "switchport mode access" on cisco switches ? thanks!
Correct Answer by pkhatri about 11 years 1 week ago
Using that command designates a port on a switch as an access port, as opposed to a trunk port. An access port carries traffic for a single VLAN whereas a trunk port can carry traffic for multiple VLANs by tagging them with 802.1q tags.
Hope that helps - pls do rate the post if it does.
Paresh
Overall Rating: 5 (1 ratings)
Correct Answer
pkhatri Sun, 08/13/2006 - 22:27
  • Purple, 4500 points or more
Paresh
pkhatri Sun, 08/13/2006 - 22:34
I must also add that you can also have access ports that are configured for voice VLAN. In such cases, one VLAN is used for voice traffic and another is used for traffic from the device attached to the IP phone.
Paresh
