Warning message
Error Configuring Interfaces for 5.x Sensors
Aug 13th, 2006
It seems my certificate just expired, so when i try configuring sensing interfaces for 5.x sensors i get the following error:
Object loading failed. An error occurred trying to get the interface information. An error occurred while trying to determine the sensor version. Detail = java.security.cert.CertificateException: Untrusted Server Certificate Chain
What are the procedures to do so.
jlively Mon, 08/14/2006 - 02:21
  • Cisco Employee,
First, check the date/time on your sensor. If it is off you can get that message.
lcuchisanmillan Mon, 08/14/2006 - 04:33
The problem is that x.509 certificate is expired and i have no idea how to renew it.
npham Thu, 08/17/2006 - 11:29
For 5.x sensor, through IDM:
Configuration > Sensor Setup > Certificates > Server Certificate
click Generate Certificate
For 4.x sensor, through IDM:
Device > Sensor Setup > Certificate > Generate Host Certificate
click Apply to Sensor
Afterwards, you may need to update the information that IPS MC has on record for the sensors. Through IPS MC:
Devices > Certificate Management
select the sensor from the side TOC
click Query to update, and Apply to save
