Warning message
3750 qos - buffer size
Aug 14th, 2006
I am putting together a VOIP qos config for a number of different switch types on of which is the 3750. We have a load of these switches an although the SRR method is different to me I think I have a handle on it.
The software config guides make numerous mention of configuring the queue sizes and weights etc in terms of buffer space percentage.
I believe that the amount of space available for egress and ingress buffers is fixed so I have a simple question.
What is the size of the total available buffer space either in bytes or number of packets ?
I cant find this anywhere. Seems to me that trying to allocate buffer space and weights without this info is more or less guessing.
I have the software config guide which is quite good but seems to leave out this kind of info, can anyone suggest a more complete document which may help ?
Many Thanks
Shaun
gpulos Mon, 08/14/2006 - 08:19
  • Blue, 1500 points or more
two things...first things first:
1) see if AutoQoS (introduced in 12.2(15)T) will work for you to create a baseline QoS requirement...this may allieviate your need to crunch so many numbers/scenarios before you actually know what QoS your network requires.
2) the queues can be shared by percentage or shaped by bandwidth.
see the following links for 3750 QoS sharing & shaping:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_white_paper09186a00801b096a.shtml#wp41099
see the following link for more info on 3750 QoS:
http://www.cisco.com/en/US/netsol/ns577/networking_solutions_white_paper09186a00801eb831.shtml
