Warning message
"vlan database" mode; What is it?
Answered Question
Aug 14th, 2006
When configuring VLANs, what is different between using "vlan database" mode and configure vlan by using interface mode? I have read somewhere that "vlan database" can not do everything abou vlan. Is that true? What command vlan database can not do? If vlan database can not do everything, what "vlan database" mode good for?
Thank you
Correct Answer by pkhatri about 11 years 1 week ago
You can configure normal-range VLANs (from 1-1005) in VLAN database mode, whereas you need to use config-vlan mode to configure extended-range VLANs (1006-4095).
Cisco now generally advises that you use config-vlan mode and not the vlan database mode, which was the older way of doing it.
Hope that helps - pls do rate the post if it does.
Paresh
Overall Rating: 5 (1 ratings)
Correct Answer
pkhatri Mon, 08/14/2006 - 21:29
  • Purple, 4500 points or more
Paresh
