Warning message
enabling broadcasting L2 switching over WAN
Aug 16th, 2006
I have two 6509-E core switches connected to each other over WAN through E1 cards, I need to enable L2 switching and full broadcasting traffic between the two core switches and the sites LAN users. Please help
jackyoung Wed, 08/16/2006 - 17:52
  • Gold, 750 points or more
Did you try to enable bridging in the E1 at all sites ? However, it create risk that broadcast over WAN may overload your WAN links. Please advise the application then we can able to help more.
Hope this helps.
mjabareen Fri, 08/18/2006 - 22:05
Thank you, this is a special sw I cannot give more details, but it needs to broadcast some traffic to all connected users even over WAN, I received from Cisco TAC that 6500 switch doesn't support IRP or broadcasting!! is there any other solution for this problem?
globalnettech Fri, 08/18/2006 - 22:37
  • Silver, 250 points or more
Hello Mohammed,
as Jack said, enabling broadcasts over the WAN by using bridging might saturate your E1 link. You might just want to give it a try and see if the traffic gets through. The config on both sides would look like this:
no ip routing
bridge 1 protocol ieee
interface Vlan1
bridge-group 1
interface serial 0
encapsulation ppp
bridge-group 1
If you run into problems with this, you might want to get in touch with your service provider (the one that provides the E1) and check if you can e.g. implement an MPLS VPN solution instead...
HTH,
GNT
mjabareen Fri, 08/18/2006 - 23:00
I tried this but no luck! bridging and routing was not supported on this 6500 core switch.
Richard Burts Sat, 08/19/2006 - 11:24
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Mohammed
Am I correct in assuming that if it is a 6500 with an E1 that the E1 is on a FLEXWAN card? If so I think that the major issue is that the VLAN switching/bridging happens on the sup but the sup does not see the lines on the FLEXWAN which are accessed from the MSFC.
I am not aware of a solution that meets your requirements on your particular hardware platform.
Rick
ilya.varlashkin Sun, 08/20/2006 - 08:20
If you could live with having only limited broadcast capability, e.g. for resolving WINS names or some other specific protocol while still routing between different subnets on both sides of E1 link for everything else, you could implement multicast between two switches and use 'ip multicast helper-map' for transporting some of broadcast traffic over E1 link as multicast then converting it back to broadcast on the other side of the link.
jackyoung Sun, 08/20/2006 - 18:17
In this case, you may consider to subscribe another WAN service, e.g. Metro Ethernet to overcome this requirement.
Or could you please advise more details that what protocol is using in the application ? Not a standard TCP/IP, DLSW, etc. I suspect the software developer should aware of this kind of limitation. If it is really the requirement, you may consider to purchase a pure bridge (but I don't know can you buy it in the market now) and connect to the 6500 LAN port. It will be much cheaper and simple. Or if you have spare dedicated router, you can also configure it as a bridge to carry the broadcast via WAN.
Hope this helps.
mjabareen Sun, 08/20/2006 - 23:34
Yes we are redesigning it with two routers on both ends, but with no use of the 6500 core switches, you know the idea simply was that the application needs to send messages and/or packets that should reach all users local and remote.
ilya.varlashkin Mon, 08/21/2006 - 00:29
transporting broadcasts over multicast for specific applications was made exactly for such purposes like yours. So you have independant IP subnets at two or more locations, most of the traffic is routed usual way, but some applications that rely on broadcast are handled in special way: 'ip multicast helper-map' will cause router to listen for broadcast traffic on the interface where it's configured, when matching broadcast packet arrives the router will encapsulate it into multicast packet, send across WAN and then router on the other side will extract data from multicast packet encapsulate them back into broadcast and send out to the LAN.
If you're interested in details of setting this up, please let me know what protocol/port your application uses I'll try to post sample config.
