Warning message
b.hsu Tue, 08/22/2006 - 08:18
  • Silver, 250 points or more
The SIP Call Transfer and Call Forwarding Supplementary Services feature introduces the ability of Session Initiation Protocol (SIP) gateways to initiate blind, or attended, call transfers. Release Link Trunking (RLT) functionality is also added with this feature. With RLT, SIP blind call transfers can now be triggered by channel-associated signaling (CAS) trunk signaling. Finally, the SIP Call Transfer and Call Forwarding Supplementary Services feature implements SIP support of call forwarding requests from a Cisco IOS gateway.
This URL should help you:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5012/products_feature_guide09186a0080108b32.html
MarkMonteleone Tue, 08/29/2006 - 18:13
We use the 2420 with callmanager on the Ether side, T1 scenario isn't typically used.
So without getting to much into this link, can this be done using the CCM4.1 or even CCM5?
