Speed Dials
Aug 16th, 2006
We need to populate each user's Speed Dials with the same set of numbers (> 50 each). Is there a way to copy from one user to the next rather than accessing each User Page via the web and adding the same set of Speed Dials?
Erik
Overall Rating: 3 (2 ratings)
baytan Wed, 08/16/2006 - 22:26
You can access the list of speed dial records of all users by SQL database.
SQL Server Enterprise manager --> CCM03XX --> "speed dials" table
But it is impossible to enter the values directly into this table because of the "pkid" and "msrepl_tran_version" columns.
So, sorry for the bad news :(
ntherond Thu, 08/17/2006 - 04:59
hi,
you use the BAT for this, to add, modify speed dials.
Nicolas
