Warning message
Problem configuring Etherchannel
Aug 19th, 2006
Could someone tell me what I'm doing wrong here please?
One side :
Cat3550-1(config)#interface range fastEthernet 0/23 - 24
Cat3550-1(config-if-range)#switchport trunk encapsulation dot1q
Cat3550-1(config-if-range)#switchport mode trunk
Cat3550-1(config-if-range)#duplex full
Cat3550-1(config-if-range)#speed 100
Cat3550-1(config-if-range)#channel-group 1 mode on
Cat3550-1(config-if-range)#shut
Cat3550-1(config-if-range)#no shut
Other side:
Cat3550-2(config)#interface range fastEthernet 0/23 - 24
Cat3550-2(config-if-range)#switch trunk encap dot
Cat3550-2(config-if-range)#switchport mode trunk
Cat3550-2(config-if-range)#duplex full
Cat3550-2(config-if-range)#speed 100
Cat3550-2(config-if-range)#channel-group 1 mode on
Cat3550-2(config-if-range)#shut
Cat3550-2(config-if-range)#no shut
Error message:
01:25:34: %PM-4-ERR_DISABLE: channel-misconfig error detected on Fa0/23, putting Fa0/23 in err-disable state
01:25:34: %PM-4-ERR_DISABLE: channel-misconfig error detected on Fa0/24, putting Fa0/24 in err-disable state
Config :
Cat3550-2#sh run int fastEthernet 0/23
Building configuration...
Current configuration : 144 bytes
interface FastEthernet0/23
speed 100
duplex full
end
Cat3550-2#sh run int fastEthernet 0/24
interface FastEthernet0/24
speed 100
duplex full
end
Cat3550-1#sh run int fastEthernet 0/23
speed 100
duplex full
end
Cat3550-1#sh run int fastEthernet 0/24
speed 100
duplex full
end
Cat3550-1#sh run int port-cha
Cat3550-1#sh run int port-channel 1
Current configuration : 116 bytes
interface Port-channel1
speed 100
duplex full
end
Cat3550-2#sh run int port-cha
Cat3550-2#sh run int port-channel 1
speed 100
duplex full
end
Edison Ortiz Sat, 08/19/2006 - 11:09
  • Hall of Fame,
    Founding Member
let's see SH VLAN from both switches.
jackyoung Sun, 08/20/2006 - 18:44
  • Gold, 750 points or more
Please refer to below link.
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_guide_chapter09186a008014f344.html#wp1033981
For Layer 2 EtherChannels:
Assign all interfaces in the EtherChannel to the same VLAN, or configure them as trunks. Interfaces with different native VLANs cannot form an EtherChannel.
If you configure an EtherChannel from trunk interfaces, verify that the trunking mode (ISL or 802.1Q) is the same on all the trunks. Inconsistent trunk modes on EtherChannel interfaces can have unexpected results.
An EtherChannel supports the same allowed range of VLANs on all the interfaces in a trunking Layer 2 EtherChannel. If the allowed range of VLANs is not the same, the interfaces do not form an EtherChannel even when PAgP is set to the auto or desirable mode.
Interfaces with different spanning-tree path costs can form an EtherChannel if they are otherwise compatibly configured. Setting different spanning-tree path costs does not, by itself, make interfaces incompatible for the formation of an EtherChannel.
For Layer 3 EtherChannels, assign the Layer 3 address to the port-channel logical interface, not to the physical interfaces in the channel.
Seems you are going to use Layer 3 mode, please remove below from interface Port-channel1 :
speed 100
duplex full
then add :
no switchport
ip addr x.x.x.x y.y.y.y
Where the interface port-channel is a logical interface, no need to configure speed, duplex, etc.
If layer 2 mode, simply delete the interface port-channel1.
Please try to follow the example.
Hope this helps.
m.lammerse Mon, 08/21/2006 - 12:38
Hi Jack,
thanks for your suggestion, but it didn't quite solve my issue. This is a simple layer-2 bonded trunk connection. I mean, even with just:
interface fas0/23
interface fas0/24
end
I should come up, but it didn't. I am thinking it has something to do with the trunk not being fully operational as the etherchannel is formed. But I am not sure.
-Marcel
m.lammerse Mon, 08/21/2006 - 12:39
Hi Edison,
unfortunately, I don't have the equipment at my disposal right now. I'll try and post the output of the command you suggested shortly.
Marcel
mchoo2005 Sun, 08/20/2006 - 22:52
If all else fails, try using "channel-group 1 mode active" on both switches, and "channel-protocol lacp" for good measure. I have always used the "active" mode (i.e. forcing IEEE802.3ad mode) and never had any problems, even between Cisco and non-Cisco (Nortel).
Anand Narayana Sun, 08/20/2006 - 23:34
  • Silver, 250 points or more
your configuration 100% perfect.While doing ether channeling, make sure that atleast one of the port is not active, because even that might disable the port. also try to avoid "speed 100 & duplex full".
hope this helps.
rate this post.
m.lammerse Mon, 08/21/2006 - 12:34
Hi anandanarayana,
I tend to agree with you that the config is correct. I double and tripple checked it. Do you know why a port might get disabled if don't shut it, like you suggested?
Cheers,
Marcel
sundar.palaniappan Mon, 08/21/2006 - 12:51
  • Green, 3000 points or more
This error typically occurs due to spanning tree problem. Perform the steps in both switches.
Can you try this:
SW1-3550#config t
Enter configuration commands, one per line. End with CNTL/Z.
SW1-3550(config)#int range f0/23 - 24
SW1-3550(config-if-range)#shut
SW1-3550(config-if-range)#channel-group 1 mode desirable
SW1-3550(config-if-range)#no shut
HTH,
Sundar
m.lammerse Mon, 08/21/2006 - 21:52
Hi Sundar,
yes, that particular configuration works. But, I did not see any spanningtree error messages. The ports get err-disabled. Could you explain a little more about why you think it would be a spanning-tree issue?
Marcel
mheusinger Mon, 08/21/2006 - 12:55
will the F0/23 and F0/24 form two separate trunks when not being bonded to an EtherChannel? Maybe you are chasing cabling or hardware issues and so on.
Regards, Martin
beckerola Tue, 08/22/2006 - 04:31
Like said in the former post, I would test the Etherchannel with different cables. The conf looks fine so it could be a physical problem (cables, connectors etc)
