Warning message
PCA Logon screen
Answered Question
Aug 21st, 2006
I'd like to edit the PCA logon screen that users are presented with, by either removing the 'domain' field, or having a fixed value present. Ideally, they should only have to enter there username and password.
I assume there's a .asp file i need to edit?
Correct Answer by Brandon Buffin about 11 years 3 days ago
The file you're looking for is:
c:\commserver\cscoserv\ciscopca\logon.jsp
Hope this helps. If so, please rate the post.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Mon, 08/21/2006 - 08:01
  • Purple, 4500 points or more
Brandon
lindborg Mon, 08/21/2006 - 08:27
  • Cisco Employee,
Just for the record - this is not supported by the BU or by TAC - if you jack up your system by messing with the source pages, your only supported path will be to reinstall. Just so you know...
azam_anwar Mon, 08/21/2006 - 11:37
Ok, thanks for the info and quick reply Brandon/Jeff.
