Warning message
Attendant console DN routing
Aug 22nd, 2006
I am trying to use AC huntgroup to route to different DNs. When I try to add the DN it says invalid DN, but the DN exists and it is in the correct partition. I am using ccm4.1(3)sr2
any ideas....
gogasca Tue, 08/22/2006 - 14:48
  • Green, 3000 points or more
Have seen this error before, but in earlier versions.
DOnt remember a report for the one you are using.
This DN is a Line for an IP phone?
No Unassigned DN?
Try recreating the Hunt Group.
Or re-adding it.
mrugeshpatel_2 Wed, 08/23/2006 - 04:36
I tried recreating the huntgroup, yes the DN is part of the IP phone.
Zin.Karzazi Wed, 08/23/2006 - 05:38
  • Silver, 250 points or more
So other DNs works fine just the one DN you mention is the problem? try deleting the DN and recreate the line again. if this doesnt help: restart the TCD Service and try again.
Remember to rate helpful posts
Zin Karzazi
