Sniffer Logs
Aug 22nd, 2006
Hi All,
When i sniff a serial T1 line using Sniffer Book.i see only frames..what could be the reason i see only frames ?
we use mgx to terminate the spans.
Actually i want to check for the source and destination ip address.
Thanks in advance
Madan
jackyoung Tue, 08/22/2006 - 18:25
  • Gold, 750 points or more
As I rememeber, there is a software come w/ the Sniffer can interpert the output log to read-able message.
Hope this helps.
o.hassairi Wed, 08/23/2006 - 00:20
normally it s an option: capture all frame or just layer2 header.
any way you can use the net-flow feature to capture details about layer3/4.
router#configure terminal
router-2621(config)#interface serial0
router-2621(config-if)#ip route-cache flow
router-2621(config-if)#exit
router-2621(config)#ip flow-export destination 192.168.9.101 9996
router-2621(config)#ip flow-export source FastEthernet 0/1
router-2621(config)#ip flow-export version 5
router-2621(config)#ip flow-cache timeout active 1
then you should use some free software that can capture netflow packets like http://manageengine.adventnet.com/products/netflow/download.html
kr_madan Wed, 08/23/2006 - 03:10
Hi Jackyoung,
Thanks for the reply.
I have checked the logs in the sniffer book software.
But in our case we enabled mux on the Multilink bundle.is this a reason that we are not able to see packet.
Madan
jackyoung Wed, 08/23/2006 - 19:20
What I think the issue is where do you probe the link, before the mux or after the mux. If before the mux, it should able to monitor the link.
I am sorry that I did not try it, so I can't help too much.
Did you check w/ the Sniffer provider, they should have more instruction in this case.
Hope this helps.
